2001 Buick Regal P0128 Low Temp
WANTING TO LEARN
can anyone tell me exactly how to change a thermostat on a 2001 buick regal GS 3.8 .where it is in the engine,?so if anyone knows where i can learn how to change it like online please let me know. my car will not pass deq because of the code P0128 and that means the coolant temperature is lower than normal. I need to save money so i want to do the repair by myself. please help!
trying to learn! about 93,000 miles
Feb 28, 2007 at 1:47 PM
CHEVY22
  • 1,375 POSTS
the code p0128 does refer to coolant temp being too low to open thermostat but it may also mean the coolant system is low on fluid or the ect sensor(temp sensor ) has failed and sending the wrong signal to the pcm
i would check the fluid level firt in the rad and fillif need and get back to me on this post and we will go from there
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Mar 1, 2007 at 3:53 AM
WANTING TO LEARN
the coolant level is not low, anything else? can I check if the thermostat is stuck in the open position without having to drain all the coolant? let me know if there is an easy way to do it.
Mar 1, 2007 at 11:26 AM
CHEVY22
  • 1,375 POSTS
yes , i would start with the thermostat , and you may need th ect too , but a thermostat should be done at that mileage anyway , look around the alternator it should be right there , and you dont have to drain the whole system but it will dain down to the point of the thermostat
jim
Mar 1, 2007 at 12:27 PM
Suggested Repair
Coolant level is already confirmed full. Start by replacing the thermostat, which is near the alternator; the system will drain only down to the thermostat. At about 93,000 miles a thermostat service is reasonable, and the ECT sensor may also need replacement if P0128 remains.
Conversation Summary
The owner of a 2001 Buick Regal GS 3.8 with about 93,000 miles has code P0128 and fails emissions because coolant temperature is lower than normal, and wants to replace the thermostat. The expert notes P0128 can also come from low coolant or a failed ECT sensor and first recommends checking the radiator level. After the owner confirms the level is not low, the expert advises starting with the thermostat near the alternator, noting the system need not be fully drained, and that the ECT sensor may also be needed.
