trying to learn! about 93,000 miles
2001 Buick Regal P0128 Low Temp
i would check the fluid level firt in the rad and fillif need and get back to me on this post and we will go from there
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
jim
Suggested Repair
Coolant level is already confirmed full. Start by replacing the thermostat, which is near the alternator; the system will drain only down to the thermostat. At about 93,000 miles a thermostat service is reasonable, and the ECT sensor may also need replacement if P0128 remains.
Conversation Summary
The owner of a 2001 Buick Regal GS 3.8 with about 93,000 miles has code P0128 and fails emissions because coolant temperature is lower than normal, and wants to replace the thermostat. The expert notes P0128 can also come from low coolant or a failed ECT sensor and first recommends checking the radiator level. After the owner confirms the level is not low, the expert advises starting with the thermostat near the alternator, noting the system need not be fully drained, and that the ECT sensor may also be needed.
