Upon starting my car this morning my security light was on and will not go off. Any help or info would be greatly appreciated!
Jun 8, 2006 at 7:37 AM
MDDGAWOLAN
MEMBER
1 POST
your chip on your key is not making contact clean it with some keyboard spray -same problem with my 1998 regal gs. Sometimes there are issues with the small wires that connect the key tumbler and the anti-theft module. This will cause the fuel pump to not run
Try performing a relearn first to see if it takes- See the guide below
DO you actually a little pellet in your key, separate key for your door?
Jan 30, 2013 at 1:02 PM
JMONEY399
MEMBER
1 POST
My security light is on and my car wont start I have heard that it is my VANT in my car is that self repairable.
Nov 19, 2018 at 10:24 AM
(Merged)
✓Experienced Mechanic
The only place that will have the proper equipment to test it is a dealer. If you need to get it started, turn the key to the run position for 10+ minutes. It should start after that.
(Merged)
