2002 Buick Regal Low Coolant Light Stays On
JHENDRIX77
I need to know if the low coolant light has to be reset with a code scanner. The light came on and I topped up the sysyem, but the light stayed on. where is this sesor located and can it be cleaned? also my reverse lights will not come on.. bulbs/fuses checked. tested for power @harness in trunk no juice..is there a reverse switch...where?
Aug 3, 2007 at 11:47 AM
SERVICE WRITER
  • 9,123 POSTS
the low coolant level sensor is most likley bad. Check around the reservior or the radiator. Not sure on that, if you don't find it I'll research it for you. Anyways, I have yet to see that light come on for any other reason. As far as the B/U lights:
https://images.2carpros.com/forum/automotive_pictures/30961_regbu_1.jpg
Aug 3, 2007 at 1:11 PM
Suggested Repair
The low coolant light most likely indicates a failed coolant level sensor; inspect around the coolant reservoir or radiator. A scanner reset was not identified as required. Reverse-light power loss was not diagnosed in writing; only a diagram was referenced.
Conversation Summary
The owner of a 2002 Buick Regal 3.8L asked whether the low coolant light must be reset with a scanner after topping up the system, where the sensor is, and whether it can be cleaned. They also reported reverse lights with no power at the trunk harness after checking bulbs and fuses, and asked about a reverse switch. The expert said the coolant level sensor is most likely bad and should be checked near the reservoir or radiator, adding they had not seen that light caused by anything else. The reverse-light reply contained only an image reference and no written diagnosis.
