I have a 2000 buick regal it has always ran great with no problems today on my way home from work it first felt like a flat tire then I realize it was missing very badly. I was close to an Advance Auto they put it on a Global OBDII scanner the codes it gave me was PO128 - coolant temp below thermostat regulation temp
PO301 cylinder 1 misfire detected
PO137 O2 sensor
Circuit low volts (bank 1 sensor 2)
the guy told me no way had it been running fine with this much wrong. I can assure it has been running fine. what is the first step we need to take to get it running rignt again
thanks
Snowtn
PO137 O2 sensor
thanks
Snowtn
Aug 8, 2007 at 11:00 AM
