i have a regal with 117000 miles on it, and recently trouble code po481 came up. both fans seem to be running fine, what else should i look for?
Aug 22, 2007 at 1:52 PM
Clear the code and road-test to see if P0481 returns. If it does, inspect the three cooling fan relays and their terminals for corrosion or sticking, then check wiring and connectors at the PCM and behind the fuse box.
A 1999 Buick Regal with 117,000 miles set code P0481, but both cooling fans appeared to run normally. The expert said the fault may be intermittent wiring, connector, or component trouble, including a relay that sticks only sometimes. They recommended clearing the code and driving first, then inspecting the three cooling fan relays, PCM connections, and the area behind the fuse box if the code returns.
