1996 Buick Regal RPM's rev high
MCK3885
  • 1996 BUICK REGAL
  • 6 CYL
  • FWD
  • 104,000 MILES
I was driving to work this morning and my car was fine and then all the sudden I went to acelerate and the car wouldn't go faster then 25 mph the rpm's were up to 3 but the car wasn't moving.
what could it be? Could it be the transmission fluid or maybe the whole transmission? Could the brakes have anything to do with it? I have to get the both calliper's replaced and the brake pads the one calliper is locked up. Could that have something to do with it?
Thanks Lindsey
Wednesday, January 14th, 2009 AT 8:40 AM
  • 109,885 POSTS
Hi:
First, check the trans fluid. Check it hot, ideling in park.
Let me know what you find.
Thursday, January 15th, 2009 AT 11:31 AM
MCK3885
Looks red and it's full.
Thursday, January 15th, 2009 AT 11:33 AM
  • 109,885 POSTS
If you put the trans in neutral, will the car coast or move? If so, it sounds like the problem may be in the trans. Let me know what you find.
Thursday, January 15th, 2009 AT 1:26 PM
MCK3885
Ok, well I took it to a shop and it is the trans, how much do they usually cost? Rebuilt? New? Labor?
Thursday, January 15th, 2009 AT 1:28 PM
  • 109,885 POSTS
The cost is all based on what needs repaired in the trans. 1200. To 2000.00 isn't out of the ordinary. Maybe you could find one with a warranty on the internet or a salvage yard near you. You may be able to save a few bucks doing it that way.
Thursday, January 15th, 2009 AT 3:22 PM
