1994 Buick Regal struts
1994 BUICK REGAL
11,360 MILES • 6 CYL • FWD • AUTOMATIC
AHNNA
Thank you for your email. I responded at least a half dozen times per your instructions and the emails were returned as not being deliverable! Anyway, a friend and I went for a ride as he "claims" to know something about cars. I have been hearing noises in the right and left rear where the humps are in my trunk and he siad the noises are due to my needing the struts replaced. I never heard of them! Is is expensive? Timeconsuming? I have put a lot of money into my buick as I was told it was worth doing and need my car to last a few more years. CAN YOU HELP ME? THANK YOU! Ahnna
Aug 23, 2009 at 2:52 AM
  • 110,244 POSTS
Can you describe when you hear the noise? Also, many times on these cars, the struts are fine, but the coil springs crack and break making a knocking sound when hitting anything rough on the road. If you bounce the rear of the car, does it stop bouncing after no more than 3 bounces? If so, the struts are fine, and chances are the strut plate is bad or a coil spring.
Sep 4, 2009 at 1:14 AM
