1993 Buick Regal code 22
140,000 MILES • 6 CYL • FWD • AUTOMATIC
BPACE12
I am getting a code 22 after i replaced the tps. I have check the connection and it does not have the locking pieces on it but other than that the wiring looks good. What can I do to repair this problem.
Yes the locking tabs are missing. It died on me today but start right up.
Jan 4, 2008 at 7:05 AM
  • 75,988 POSTS
Are you talking about the locking tabs on the wiring connector if so just use superglue around it-this will also seal it.
Jan 4, 2008 at 7:15 AM
BPACE12
Jan 4, 2008 at 1:08 PM
BPACE12
will that fix the code 22 I'm getting
Jan 5, 2008 at 3:53 AM
  • 75,988 POSTS
If its connected and tightly secured on it. if not there's still problem You might want to clear the code and see what happens.
Jan 5, 2008 at 4:13 AM
BPACE12
Ok Thank you, I'll give it a try.
Jan 5, 2008 at 4:17 AM
