1997 Buick Park Avenue Fuel Filter Location Fix
Spark Plug
Removal Procedure
Turn OFF the ignition switch.
Caution: Wash your hands after handling coated spark plugs and before smoking. The coating is a non-hazardous material and incidental contact will not cause any adverse effects. However, exposure to polymer vapors - the result of contamination of cigarette products and subsequent burning of the polymer - may result in flu-like symptoms and should be avoided.
Spark plug wires from the plugs. Note the position of the wires before removing. Twist the boot 1/2 turn while removing.
Important
Do not remove spark plugs when engine is warm.
Clean dirt and debris from spark plug recess area.
Remove the spark plugs from the engine.
Installation Procedure
Install the spark plugs. Tighten
Tighten the spark plugs to 15 N·m (11 lb ft).
Important
Aluminum heat shields are used over the spark plug boots on the cylinders which are close to the exhaust tubing. Care should be taken in order to ensure these heat shields are fully seated.
Install the plug wires to the proper spark plugs. Use the position reference noted during the removal procedure.
Suggested Repair
Locate the fuel filter under the vehicle toward the rear wheels on the driver side; it looks like a small silver can with a fuel line at each end. For spark plugs, turn the ignition off, note wire positions, twist each boot a half turn to remove it, and do not remove plugs from a warm engine. Clean debris from the recesses, install plugs to 15 N·m (11 lb ft), fully seat any aluminum heat shields, and reconnect the wires in the noted order.
Conversation Summary
The owner of a 1997 Buick Park Avenue with 125,000 miles and a 6-cylinder engine asked where the fuel filter is and how to replace the spark plugs. The expert said the filter is under the vehicle toward the rear wheels on the driver side and looks like a small silver can with a fuel line at each end. Spark plug guidance was to shut off the ignition, mark wire positions, twist boots a half turn, avoid removal on a warm engine, clean the recesses, tighten plugs to 15 N·m (11 lb ft), fully seat heat shields, and reinstall the wires correctly.
