1997 Buick Park Avenue MAP Vacuum
SLICK47
97 Buick Park Ave, 3800, 160,000 miles, checked pressure at MAP sensor, my understanding is you should have a positive pressure for sensor to work...what I discovered is a negative pressure (vacuum). What could the problem be?
Jul 29, 2007 at 3:20 PM
CLY
  • 308 POSTS
The map sensor works off of vacuum. At Idle with high vacuum(17 to 20 inchs) It will read somewhere below 2 volts and with the vacuum removed it will read up to 5 volts. As the engine is operated say under wide open throttle the vacuum level will decrease and the MAP sensor voltage will increase.
Cly
Jul 29, 2007 at 9:56 PM
Suggested Repair
No repair is indicated for vacuum at the MAP sensor. It is designed to read engine vacuum. At idle (about 17-20 inHg) expect under 2 volts; with vacuum removed, up to about 5 volts. Voltage should rise as vacuum falls under load or wide-open throttle.
Conversation Summary
The owner of a 1997 Buick Park Avenue with a 3800 engine found vacuum rather than positive pressure at the MAP sensor and thought that indicated a fault. The expert explained that the MAP sensor operates on vacuum and described the normal voltage response as vacuum changes.
