1988 Buick Park Avenue Dies
CRYMAC
hi i have a 1988 buick park avenue, close to 200,000 and i believe its a v6 (not sure what size that is) and my car keeps dying on me, i was told that it was a mass air flow sensor but the one for that year is expensive and hard to find just wandering if any other year would work?
Jul 18, 2007 at 2:06 PM
CLY
  • 308 POSTS
Not that I know of.....One forsure way to tell is to take something and tap on the sensor. You will notice the idle change or the car will dye. Just tap on it don't hit it hard....That was a common problem on those cars....
Cly
Jul 18, 2007 at 11:21 PM
Suggested Repair
Lightly tap the mass air flow sensor while the engine is idling. If idle changes or the engine dies, the sensor is likely failing, a common issue on these cars. The expert does not know of a compatible sensor from another year.
Conversation Summary
The owner of a 1988 Buick Park Avenue with nearly 200,000 miles says the car keeps dying and was told the mass air flow sensor may be at fault. They asked whether a sensor from another year would work because the correct part is expensive and hard to find. The expert said they do not know of an interchange and recommended lightly tapping the sensor; an idle change or stall indicates the common sensor problem.
