1997 Buick Park Avenue sucking like vac through the oil cap
1997 BUICK PARK AVENUE
174,000 MILES • 6 CYL • FWD • AUTOMATIC
TWOINE
I have vacuum sucking through the place where you screw the oil cap in and through the dip stick housing but all the actual vacuum ports are working too. I replaced the upper and lower intake manifold gaskets and the ploblem still assist. what can I do to fix this problem?
Feb 26, 2010 at 1:35 AM
DOCFIXIT
  • 18,828 POSTS
Hi
PCV maybe blocked remove see if suction is felt on valve.
Let me know
Thanks for donate
Feb 26, 2010 at 6:49 AM
TWOINE
I had already checked for suction in the valve and also rechecked after you told me to.Yes it does have pretty good suction from there.
Mar 2, 2010 at 2:22 AM
DOCFIXIT
  • 18,828 POSTS
What is the fault ? Running bad? no power?
Mar 2, 2010 at 4:57 AM
TWOINE
Whats going on is that when the car is running, there isn't any oil on the dip stick at all and runs fine with a sound like theres no oil in the engine but when I take the oil filler cap off, it runs with a miss and I get plenty of oil on the dip stick without the sound that I explained above.
Mar 4, 2010 at 2:07 AM
DOCFIXIT
  • 18,828 POSTS
Think what is happening is no filtered air is entering crankcase. The PVC pulls air out causing vacuum while filtered air is drawn in the crankcase. Find a hose that should come from air snorkle after air filter and goes to valve cover see if it is restricted.
Mar 4, 2010 at 7:18 AM
TWOINE
There isn't a hose running to any of the valve covers and no port for one. And the pcv valve is located on the upper intake manifold with a sensor that locks in over it.
Mar 4, 2010 at 11:15 AM
DOCFIXIT
  • 18,828 POSTS
Is there a knocking sound coming deep within engine?
Mar 9, 2010 at 1:31 AM
