1994 Buick Park Avenue 250,000 mi. Won't reverse unless you put it in low first , then reverse.
Jan 27, 2007 at 4:39 AM
Check and adjust the shift linkage. Move the lever from Park to the lowest drive gear and confirm a detent is felt at each position; if not, adjust the linkage and verify the gear position indicator matches.
The owner of a 1994 Buick Park Avenue says it will not go into reverse unless shifted into low first. One reply suggested a broken shifter cable or cable ends. The expert advised checking linkage adjustment by feeling for detents from Park through the lowest drive gear and watching the gear position indicator.
