1998 Buick Park Avenue Rear Calipers
STORMT497
  • 5 POSTS
I'm changing the brakes on a 1998 Buick Park Avenue Ultra and I'm having trouble decompressing the rear calipers. I'm not sure what the mileage has to do with my problem but I have 97K miles and the engine size is 3.8 Liter. I have already changed the front brakes. How do I decompress the rear calipers????
Jul 5, 2007 at 8:03 AM
SERVICE WRITER
  • 9,123 POSTS
I believe those have a piston that get turned in as pressure is applied. Look for threads on the piston or a slot going through the center of the face of the piston. There is a special tool needed for that. hopefuly it did't get damaged from forcing it.
Jul 5, 2007 at 8:08 AM
STORMT497
  • 5 POSTS
I noticed 2 notches on the piston but I did not see any treading. I didn't force the piston either. I got to the point where there is pressure and notice that the piston didn't move so I stopped and now I'm here looking for help. Thank You for your comment I'll look again.
Jul 5, 2007 at 8:23 AM
SERVICE WRITER
  • 9,123 POSTS
You need a spanner wrench to turn those calipers in, I was wrong on the description, but right on the tool.
Jul 5, 2007 at 9:40 AM
STORMT497
  • 5 POSTS
Thank You very much I'll look for the wrench. I'll let you know if that solves the problem.
Jul 5, 2007 at 3:07 PM
EDBEARD
You can rent a tool from AutoZone, or other auto parts stored just for that purpose. At AutoZone in Austin Texas, it rents for $29. You get your money back when you bring back the tool. If you don't bring it back then the $29 covers the cost of the tool.
Jul 6, 2007 at 1:07 PM
STORMT497
  • 5 POSTS
I found a universal piston turner at Advanced AutoParts for $11 and that fixed it. The tool is a square block with 5 different settings for different sized pistons. Thanks for your help.
Jul 11, 2007 at 12:22 AM
SERVICE WRITER
  • 9,123 POSTS
Cool! Another success story!
Jul 11, 2007 at 3:43 AM
Suggested Repair
Do not force the rear caliper pistons straight in. Use a caliper piston wind-back tool or spanner wrench to rotate the pistons back into the bores. A rental tool or an inexpensive universal piston turner can do this.
Conversation Summary
The owner of a 1998 Buick Park Avenue Ultra could not retract the rear brake calipers after replacing the front brakes. The pistons had notches but no visible threads and would not move under pressure. Advice was that these pistons must be turned in with a special tool rather than pushed. A rented tool was suggested, and a universal piston turner from an auto parts store successfully retracted the pistons.
