1994 Buick Park Avenue Check Engine Light
MAGMAN0689
1994 Buick Park Av Ultra 156,000 miles 3.8 supercharged-----
As soon as I start the car it is fine thenabout a mile the check engine light comes on and it runs rough,, now if I pull over and shut off the car and restart it goes off, it runs for about 1-7 miles doun the road then it comes on,runs rough --and same thing...pulll over etc.. Now if I dont pull over to shut it off, and keep it running rough it stalls and dies,, I tried this, I pulled over with the check engine light on and kept it running at idle it ran like crap after a few minutes, i pressedthe gas and it went back to normal..heeep me ,,thanks
Mar 9, 2007 at 11:40 AM
CHEVY22
  • 1,375 POSTS
hi
the best advise i can give right now is have the codes read , this will give an idea of what is failed , not completely but and idea , if you get them read you can give us a shout and we will be glad to help from there
Mar 10, 2007 at 12:07 AM
Suggested Repair
Have the diagnostic trouble codes read to identify the failed system, then follow up with those codes for further diagnosis.
Conversation Summary
A 1994 Buick Park Avenue Ultra with a 3.8 supercharged engine starts normally, then the check engine light comes on after about a mile and the engine runs rough. Restarting clears the light temporarily, but the problem returns within a few miles. If left running, it can stall; at idle it runs poorly until the throttle is pressed. The expert advised reading the trouble codes and reporting them for further help.
