I have 1 1992 Buick Park Avenue with the 3.8 liter motor, 149,000 miles. How do you reset the change oil light?
Nov 17, 2007 at 1:09 AM
✓Experienced Mechanic
There is a little hole in the plastic dash cover down low on the passengers side. Use a tooth pick and press the reset switch and hold for 15 seconds until the light goes out. Some times you need to do it more than once.
Please let me know if this does not work by hitting the negative vote tool below.
