1992 Buick Park Avenue
CREATIVEARTIST
  • 1992 BUICK PARK AVENUE
Electrical problem
1992 Buick Park Avenue 103010 miles
when I turn the key all the lights come on like its going to start but when I try to start it, it does not turn over I can jump the starter but it dies. The fuel pump is runnig. What could be the problem.
Thursday, March 6th, 2008 AT 9:28 PM
ED ARMES
  • 129 POSTS
Sounds like a failed ignition switch, ignition wiring harness or fusible link at the starter. Somewhere the circuit is not being completed. If the starter system is not reading the key in start or run mode, you can jump start it all day but it won't keep running. Ignition switch is buried under the steering wheel. Harness runs through column to under the dash and fusible link is at the starter solenoid.
Saturday, March 15th, 2008 AT 10:28 PM
