1991 Buick Park Avenue no start
GTP
  • 1991 BUICK PARK AVENUE
  • 6 CYL
  • 138,000 MILES
Car has fire and fuel good compression computer keeps setting code 41 mel-cal or emc problem. Also backfires through muffler when you turn loose of ignition switch. Any ideas
Friday, January 11th, 2008 AT 4:37 PM
MASTERTECHTIM
  • 4,750 POSTS
Im pretty sure that code requires replacement of the cars ecm and or the prom.
Friday, January 11th, 2008 AT 4:46 PM
MASTERTECHTIM
  • 4,750 POSTS
Are you sure code 41 is memcal code. I dont have my alldata running right now so I cant double check. I thought the memcal code was 51. I think 41 is cam sensor but im not a hundred percent sure. If you still are having trouble tomorrow, post again and ill research it for you.
Friday, January 11th, 2008 AT 4:50 PM
GTP
Code 41 in my book is module if carb or mem-cal or emc problem if fuel injected
Friday, January 11th, 2008 AT 4:55 PM
