1986 Buick Skyhawk Won't Move in Gear
BUICK
BILLIEZ
86 Buick Skyhawk, 150,000 miles
Daughter pulled up to an intersection today and pushed the clutch in and went to shift it into gear and car wouldn't move. Clutch is not spongy nor
does it go all the way to the floor. She says it has
the same pressure it's always had. While she sat
at the intersection, she was able to move the gearshift to all the gears while engine was running without her foot on the clutch. Is it a clutch gone out, a stuck clutch, lack of fluid or what?
Thank you,
Billie
Dec 19, 2006 at 8:04 AM
MATHIASO
  • 1,209 POSTS
this may be a shift linkage problem
If the the linkage cannot move enough to fully engage a gear,transmission/transaxle will jump out of gear while it is under a load
two causes has been identified with this problem:
The upshift light interferes with shifter or there are improper shifter to shifter boot clearances.Both connditions prevent the transaxle's shift forks from moving enough to fully engage the sychronizer collars to their mating gears.
if correcting these problem does not solve the problem , the cause may be the engine mounts or an internal problem in the engine.
Dec 23, 2006 at 3:59 AM
Suggested Repair
Inspect the shift linkage for incomplete gear engagement. Check whether the upshift light interferes with the shifter or the shifter-to-boot clearance is too tight. If correcting those does not fix it, inspect the engine mounts and consider an internal engine problem.
Conversation Summary
A 1986 Buick Skyhawk with 150,000 miles would not move after the driver pressed the clutch and tried to select a gear. The clutch pedal still had normal pressure and did not go to the floor, and the shifter could be moved through all gears with the engine running and the clutch pedal released. The expert suggested a shift-linkage problem that prevents full gear engagement, possibly from upshift-light interference or improper shifter-boot clearance, and recommended checking engine mounts or an internal engine problem if those corrections do not help.
