1988 Buick LeSabre Rough Running Codes
AYMINCENDIARY
I have an '88 Buick LeSabre which is running rough. I had the car put on the computer and the printout came back with these error codes:
Vehicle scanned: 1988 Buick LeSabre C=3.8L PFI (3800)
Diag. Trouble codes
History Code 22
Throttle Position Sensor (TPS) Signal voltage is too low
Current code 23
Manifold Air Temp (MAT) Sensor Signal too low
History Code 23
Current Code 41
Camshaft Sensor Loss of Signal
History Code 41
History Code 48
Misfire Symptom
Let me know what is involved with this repair. I will change out the sensors in question. I would appreciate knowing what snags I may run into beforehand. I will have the tools and the repair manuals on hand when I do this repair.
Thanks!
Chris
Aug 12, 2007 at 12:03 PM
MERLIN2021
  • 17,250 POSTS
I would change the cam sensor and clear the codes and see what happens next!
Aug 13, 2007 at 5:56 AM
AYMINCENDIARY
[quote:a28d02b6e4="merlin2021"]I would change the cam sensor and clear the codes and see what happens next![/quote:a28d02b6e4]
I'll go with that and see what happens. BTW, the Haynes manual said to check for a missing magnet on the cam sprocket, however if that was missing, I don't think the car would even start.
The vehicle runs, but I don't want to take it far or go over 45.
Aug 13, 2007 at 7:09 AM
Suggested Repair
Replace the camshaft sensor, clear the trouble codes, and recheck to see which codes return.
Conversation Summary
A 1988 Buick LeSabre runs rough and shows history code 22 for low TPS voltage, current and history code 23 for low MAT sensor signal, current and history code 41 for camshaft sensor signal loss, and history code 48 for misfire. The owner plans to replace the related sensors and asks about possible snags. The expert recommends changing the cam sensor first, clearing the codes, and seeing what happens next. The owner agrees and notes the car runs but should not be driven far or above 45 mph.
