1994 Buick LeSabre CEL and High Idle
and
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Cheers
Are you having any driveability issues with vehicle?
Thanks, Steve
Check resistance between B & C, then A & D terminals, infinite resistance, If not replace iac.
It sounds to me like the iac is working correctly. With engine idling, block off the mouth of throttle-body, does it kill the engine?
that takes a special adapter and scanner is only way to read codes if it has 12 pins as it should cross A&B with paper clip watch engine light flash with key on count flashes.
Please let us know what you find.
Cheers
What problem are you having?
Suggested Repair
Use a professional or GM-capable scan tool for this transition-year 16-pin OBD1 system; generic OBD2 readers and a simple jumper may not retrieve codes. Also verify power at connector pin 16, clean the throttle body, test the idle air control valve, and check for unmetered air if idle stays near 2500 rpm.
Conversation Summary
A 1994 Buick LeSabre has a check engine light and a 16-pin connector, but parts-store OBD2 scanners report no data. The owner also reports idle rising to about 2500 rpm at startup and dropping when the idle air control connector is unplugged. Experts explain that this is a transition vehicle with an OBD1 system behind an OBD2-style connector, so a professional scan tool or special adapter is needed. They also suggest checking connector power and testing or cleaning the throttle body and idle air control valve.
