Does anyone know how to bleed the brakes on a 2001 Buick LeSabre Limited? I heard that there is a special procedure for it.
Jan 28, 2007 at 6:58 PM
Disconnect the negative battery cable so the ABS module has no power, then bleed the brakes using the normal procedure.
The owner asked how to bleed the brakes on a 2001 Buick LeSabre Limited and whether a special procedure is required. The expert said nothing special is needed beyond keeping power off so the ABS module does not become air bound. Disconnect the negative battery cable, then bleed the brakes as on any other car. This guidance applies to ABS-equipped vehicles generally.
