2001 Buick LeSabre Chugging
MICHBOWHUNTER
95,662 miles on 3800 engine. Service engine soon light is on. During winter months noticed a chug while accelerating once in a while. I hooked up a computer scanner(Snap-On) found no codes. However, I noticed that the EGRvalve had no voltage output regardless of engine RPM......Now it is summer(A/C on) Severe chugging during acceleration during each and every accelleration. I suspect the EGR valve. But at the cost of $300 would like to be quite certain. Could a clogged catalystic converter cause this???????????????????????
Aug 6, 2007 at 1:01 PM
CLY
  • 308 POSTS
You say that there is a service engine soon light on now? What code are yo geting out of the PCM?
Cly
Aug 6, 2007 at 1:35 PM
MICHBOWHUNTER
[quote:7323e68d24="Cly"]You say that there is a service engine soon light on now? What code are yo geting out of the PCM?
Cly[/quote:7323e68d24]
Being an aircraft mechanic......not sure what PCM is. But there were no codes when the scanner was hooked up. Even though the EGR valve showed no voltage output.... no code was shown for it .
Thanks
Aug 6, 2007 at 1:58 PM
CLY
  • 308 POSTS
The PCM is the powertrain contro module. It seems strange that the service engine soon light is on and no codes are in the computer. The EGR valve will usually cause a rough idle if stuck open and affect gas mileage if it is stuck shut. I would lean more towards and ignition problem...
Cly
Aug 6, 2007 at 10:12 PM
Suggested Repair
Before replacing the EGR valve, recheck for stored codes and inspect the ignition system. A stuck-open EGR usually causes a rough idle, while a stuck-closed EGR mainly hurts mileage; the expert did not confirm a catalytic converter as the cause.
Conversation Summary
The owner of a 2001 Buick LeSabre with a 3800 engine reports chugging during acceleration, worse with the A/C on, plus a service engine soon light but no scanner codes. The EGR valve showed no voltage output. The expert notes that no codes with the light on is unusual, explains typical EGR symptoms, and leans toward an ignition problem rather than the EGR valve.
