1998 Buick LeSabre P0507 High Idle
LARRYWW
I have 140,000 miles on the car. I just changed the plastic intake manifold and now I keep getting the engine light that has a code PO507. It means the Idle speed control motor needs work. How can I clean it or replace it?
Feb 22, 2007 at 3:06 AM
CHEVY22
  • 1,375 POSTS
what engine please???
Feb 22, 2007 at 3:41 AM
CHEVY22
  • 1,375 POSTS
the code is for iac system rpm high , there are many resons for this code ,since you replaced the intake check for vacuum leaks and also the iat sensor harness pulgged in ,it is on the air intake , it has two wiresand it is before before maf , check the intake for leaks since it was just replaced ,and after that we can work on the iac it is located on rge t/b
Feb 22, 2007 at 4:01 AM
Suggested Repair
After the intake replacement, check for vacuum leaks and confirm the two-wire IAT sensor harness on the air intake ahead of the MAF is connected. If those checks are good, inspect or service the idle air control motor on the throttle body.
Conversation Summary
A 1998 Buick LeSabre with 140,000 miles set code P0507 after the plastic intake manifold was replaced. The owner asked how to clean or replace the idle speed control motor. The expert asked which engine it has and said the code means IAC system RPM is high, which has several causes. They advised checking for intake vacuum leaks and a connected IAT sensor before working on the IAC at the throttle body.
