2000 Buick Lesabre
DIY HOME TECH
Engine Mechanical problem
2000 Buick Lesabre 6 cyl Two Wheel Drive Automatic
need info on how to jump out ALDL plug to get service engine diagnostic codes
Mar 6, 2010 at 12:51 PM
ERNEST CLARK
  • 1,730 POSTS
You don't have an ALDL connector. Yours is called a "DLC", (Data Link Connector).
Also, your's is "OBD II", which means you can no longer access your diagnostic trouble codes by jumping wires across the terminals.
You'll need an OBD II scan tool. And keep in mind, all scanners aren't created equal.
A GM scan tool is capable of reading all PCM, ABS, BCM and transmission codes. Most aftermarket scan tools that are bought in a store can't do this. (Snap-on, Mac, Matco brands can but they'll cost you thousands of dollars)
Mar 9, 2010 at 11:47 PM
