1998 Buick Lesabre Heater Blower
1998 BUICK LESABRE
43,000 MILES • 6 CYL • FWD • AUTOMATIC
S CLINE
Even though the engine has been warmed to 190 degrees at an idle (outside temp is below zero) the blower will not kick on, thus the inside of the car remains cold. After driving at road speeds for about 5 miles, blower will kick in and you get all of the heat you need. Battery is new and alternator is charging where it should be. It appears that something is telling the blower fan not to run like a sensor or something??? Thanks
Jan 1, 2008 at 8:05 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
[quote:5cc7fd4a52="s cline"]Heater problem
1998 Buick Lesabre 6 cyl Front Wheel Drive Automatic 43000 miles
Even though the engine has been warmed to 190 degrees at an idle (outside temp is below zero) the blower will not kick on, thus the inside of the car remains cold. After driving at road speeds for about 5 miles, blower will kick in and you get all of the heat you need. Battery is new and alternator is charging where it should be. It appears that something is telling the blower fan not to run like a sensor or something??? Thanks[/quote:5cc7fd4a52]
after it works does it operate at all speeds
if so i will check and test the blower motor 1st
Jan 1, 2008 at 8:13 PM
