1998 buick le sabre
LARRYWW
I have 140,000 miles on the car. I just changed the plastic intake manifold and now I keep getting the engine light that has a code PO507. It means the Idle speed control motor needs work. How can I clean it or replace it?
Feb 22, 2007 at 3:06 AM
CHEVY22
  • 1,375 POSTS
what engine please???
Feb 22, 2007 at 3:41 AM
CHEVY22
  • 1,375 POSTS
the code is for iac system rpm high , there are many resons for this code ,since you replaced the intake check for vacuum leaks and also the iat sensor harness pulgged in ,it is on the air intake , it has two wiresand it is before before maf , check the intake for leaks since it was just replaced ,and after that we can work on the iac it is located on rge t/b
Feb 22, 2007 at 4:01 AM
