Hi:
The headlamp is replaced from the rear of the headlamp assembly. You need to open the hood, locate the the bulb, disconnect the electrical plug, and there is a is a circular hold down that holds the bulb in the assembly. Turn it to loosten it, remove the bulb. and replace it. Try not to touch the glass section of the new bulb with your hands.
Let me know if you have any questions.
Nov 3, 2008 at 11:31 AM
