I have a 1994 Buick Le Sabre that only leak oil when the engine is running. I took it to a shop and was told it was the gasket for the "Oil Filter Housing" .
I have had the gasket replaced, but the leak still occurs when the engine is running.
THe oil runs down to the ground from the area of the oil filter housing loosing up to 2 quarts a day.
Can you give me any idea on where the leak is comming from ?
Thank You................................................
Aug 26, 2009 at 9:28 AM
