1994 Buick LeSabre CEL and High Idle
DARRELL COATS
Shows check engine light. Need to pull codes, but has 16 pin connector but not obdi1 system.
May 1, 2007 at 8:30 AM
TCCC143
  • 21 POSTS
Here is both the method for getting codes for OBD2 and OBD1
and
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Cheers
Nov 8, 2007 at 10:39 AM
STEVE
Jump 5 to 6 on diagnostic connector no flashes. Any suggestions?
Aug 27, 2018 at 3:47 AM (Merged)
JDL
  • 16,098 POSTS
If that is a 16 pin datalink connector, a jumper wire won't work. At the least, you need an obd2 code reader, plugs into the datalink connector. Your local autostore should sell an obd2 code reader. Some national brand autostores will check codes for free.
STEVE
it is a 16 pin Ben to autozone and 2 other auto parts stores all scans come up no data connection
JDL
  • 16,098 POSTS
Pin 16 should be voltage, any voltage on that pin? If no voltage, the datalink connector wont work.
Are you having any driveability issues with vehicle?
STEVE
yes the idols is up to 2500 rpm does at start up if I pull connectionconnection to IAc Idol drops down
JDL
  • 16,098 POSTS
Did you clean the throttle-body and idle air control? What about pin 16 on the datalink connector, use a testlite, any voltage?
SMMCFARLAND2
This vehicle is OBD1 COMPLIANT, but it has an OBD2 connector. Is there a scanner I could buy for what has been suggested as obd1.5? How about jumping pins to get the mil to flash?
Thanks, Steve
JDL
  • 16,098 POSTS
Just to add, You can check resistance across A & B terminals, then C & D terminals, 40--80 ohms. If not as specified replace iac.
Check resistance between B & C, then A & D terminals, infinite resistance, If not replace iac.
It sounds to me like the iac is working correctly. With engine idling, block off the mouth of throttle-body, does it kill the engine?
HMAC300
  • 48,601 POSTS
That is obd1 certified and it has a 16 pin connector that only 6 pins are used and it has the same shape as the obd2 connectors but obd2 code readers do not work.
that takes a special adapter and scanner is only way to read codes if it has 12 pins as it should cross A&B with paper clip watch engine light flash with key on count flashes.
Please let us know what you find.
Cheers
JESSE777
  • 37 POSTS
These take a unique scanner/software to read. They are partially OBD1 & OBD2, oddballs.
What problem are you having?
MARKHELLION
Engine running rough, check engine light on,has an obd2 connector cannot hook up.
WRENCHTECH
  • 20,758 POSTS
You are in a transition year. You have an OBD2 connector but and OBD1 system. The only thing that will access that one is a professional scan tool.
Suggested Repair
Use a professional or GM-capable scan tool for this transition-year 16-pin OBD1 system; generic OBD2 readers and a simple jumper may not retrieve codes. Also verify power at connector pin 16, clean the throttle body, test the idle air control valve, and check for unmetered air if idle stays near 2500 rpm.
Conversation Summary
A 1994 Buick LeSabre has a check engine light and a 16-pin connector, but parts-store OBD2 scanners report no data. The owner also reports idle rising to about 2500 rpm at startup and dropping when the idle air control connector is unplugged. Experts explain that this is a transition vehicle with an OBD1 system behind an OBD2-style connector, so a professional scan tool or special adapter is needed. They also suggest checking connector power and testing or cleaning the throttle body and idle air control valve.
