HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Lesabre
Brakes
Wheel Cylinder
1992 Buick Lesabre
MAMADUKES
MEMBER
1992 BUICK LESABRE
1992 Buick Lesabre 6 cyl Front Wheel Drive Automatic
my car will not go over 20 miles an hour and it also shakes when you accelerate
Friday, April 24th, 2009 AT 6:36 PM
BMRFIXIT
MECHANIC
Check exhaust system for restriction
is it due for tune up
check if firing on all cylinders
also what do you have for fuel pressure ?
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, April 25th, 2009 AT 4:50 PM
Please
login
or
register
to post a reply.
Related Wheel Cylinder Content
1992 Buick Lesabre Brake Problems
My Brake Light Came On And The Rear Left Wheel Cylinder Was Leaking So I Replaced It And Bled It. My Car Has Disc Brakes In The Front And...
Asked by
mcdowellj
1 ANSWER
1992
BUICK LESABRE
GUIDE
Wheel Cylinder Replacement
A brake system wheel cylinder is used to push against a set of brake shoes to help stop the car.
1994 Buick Lesabre Totally Clueless
Electrical Problem 1994 Buick Lesabre 6 Cyl Front Wheel Drive 132000 Miles When I Manualy Adjust The Airflow Into The Cabin With The...
Asked by
bigdaddy51
1994
BUICK LESABRE
1994 Buick Lesabre Vats Fuel Enable Wire
Electrical Problem 1994 Buick Lesabre 6 Cyl Front Wheel Drive Automatic 160k Miles I Need To Know What Color Is The Fuel Enable Wire On...
Asked by
texas409
1 ANSWER
1994
BUICK LESABRE
2000 Buick Lesabre Oil
Engine Mechanical Problem 2000 Buick Lesabre 6 Cyl Front Wheel Drive Automatic Why Is Th E Oil Life Index At 0%?
Asked by
starjeagle
1 ANSWER
2000
BUICK LESABRE
1992 Buick Lesabre No Pressure In Brake Pedal
I Have No Pressure In My Brake Pedal. I Had My Brakes Blead In The Front Only. I Don't Hear Any Grinding In The Pads And There Is No Leak...
Asked by
michellepressley
1 ANSWER
1992
BUICK LESABRE
VIEW MORE
Brake Shoe and Drum Replacement
Brake System Flush
Bleed Brakes
