1988 Buick Lesabre
LILA SANCHEZ
  • 1988 BUICK LESABRE
  • 6 CYL
  • FWD
  • 178,000 MILES
I want to no how to take off a crank shift pully and replace it with a neew one
Saturday, October 25th, 2008 AT 9:24 PM
BMRFIXIT
  • 19,053 POSTS
CRANKSHAFT POSITION SENSOR ("A", "C", "E", "H" & "H" BODIES - VIN "B", "E" & "L")
Removal
1.Disconnect negative battery cable. Remove serpentine belt. Raise vehicle on hoist.
2.Remove inner fender splash shield. Remove crankshaft balancer bolt.
3.On "A" and "E" bodies, slide balance toward right fender/cradle.
4.On "C", "H" and "N" bodies, remove crankshaft balancer.
5.On all models, remove crankshaft sensor mounting bolts. Remove sensor. Disconnect crankshaft sensor harness connector.
Installation
To install reverse removal procedure. Tighten sensor bolts to 22 ft. lbs. (30 N.m) and crankshaft balancer bolt to 200 ft. lbs. (270 N.m). Ensure "T" latch on sensor harness connector is properly engaged.
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, October 25th, 2008 AT 11:35 PM
