1986 Buick Electra Digital Dash Blank
JEFFO
Hi I have an 86 buick park avenue ,last weekend I changed the heater core ,things went really well until I re attacted the battery ,it seems that I lost the correct reading for the mileage and then this morning when I started the car the digital dash cluster was not showing any thing just a big black empty space looking back at me.
what do I have to do to fix this problem ,what do you think is the cause . keep in mind I am broke.
Jul 29, 2007 at 11:31 PM
MERLIN2021
  • 17,250 POSTS
How did you hook up the battery? Should always attach positive cable first. Then after you do that to make shure. Check the fuses and the poer distribution box for bad fuses and relays!
Aug 10, 2007 at 7:05 AM
Suggested Repair
Reconnect the battery with the positive cable first, then the negative. Check the fuses and the power distribution box for blown fuses or bad relays that could leave the digital cluster dark.
Conversation Summary
After a heater core replacement on a 1986 Buick Park Avenue Electra, reconnecting the battery caused an incorrect mileage reading, and the next morning the digital dash was completely blank. The expert advised attaching the positive battery cable first and checking fuses and relays in the power distribution box.
