1998 Buick Century Window Won't Close Fully
SJLORENZ
I purchased a replacement window regulator for my 98 Buick Century (rear passenger). After I installed, the window does not completely close as it leaves a 1/2 inch gap. Is there an adjustment that can be made or is it bad regulator? It does not seem that the screws slots are adjustable either.
Oct 16, 2007 at 11:04 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a590b3607e="sjlorenz"]I purchased a replacement window regulator for my 98 Buick Century (rear passenger). After I installed, the window does not completely close as it leaves a 1/2 inch gap. Is there an adjustment that can be made or is it bad regulator? It does not seem that the screws slots are adjustable either.[/quote:a590b3607e]
You may picked up the wrong regulator
Check with the part store that sold you the part.
I don’t know of any adjustment on the regulator to take the gap of ½ in
Good luck
Oct 16, 2007 at 11:21 AM
Suggested Repair
Confirm with the parts store that the correct rear window regulator was supplied. There is no known regulator adjustment that will close a half-inch gap.
Conversation Summary
The owner installed a replacement rear passenger window regulator on a 1998 Buick Century, but the window still leaves about a half-inch gap and the mounting slots do not appear adjustable. The expert says there is no known adjustment for that gap and the wrong regulator may have been purchased, so the seller should be checked.
