1995 Buick Century Front Windows Fail
GMC
BRICAR157
I have a 1995 Buick Century Custom Wagon with 110000 miles. Both front power windows stopped operating recently. The back windows are working fine. I replaced the main electric switch in the driver's side door but the problem remains.
May 4, 2006 at 12:54 AM
LOSONE
  • 1,616 POSTS
The power window motors are a high failure item and probably need to be replaced. Any parts store has them. It is a tough job to replace unless you have done it a few times. good luck
May 4, 2006 at 1:14 AM
Suggested Repair
Replace the front power window motors. They are a common failure item and are available at parts stores; the job is difficult without prior experience.
Conversation Summary
The owner of a 1995 Buick Century Custom Wagon says both front power windows stopped working while the rear windows still work. Replacing the driver's door master switch did not fix the problem. The expert says the power window motors commonly fail and likely need replacement, which is available at parts stores but is a difficult job without experience.
