1991 Buick Century Steering Column Snap Ring Fix
JOHN PECKHAM
'91 Buick Century, 90000 miles, 3.3L
I had to replace a spring inside the steering column as the left turn signal would not cancel automatically. All went well until I tried to reassemble. I can't seem to compress the large spring in the center of the column, plastic spring retainer, and metal plate enough to ge the snap ring back in on the column. Do I need a special tool or am I just a wimp?
Jul 16, 2007 at 1:34 AM
CLY
  • 308 POSTS
Hey John....
You do need a special tool to get that retainer back on. You can get on from an autozone or a place like that that rents tools.I am sure it wouldn't be much to rent it. With the proper tools it is a snap..
Cly
Jul 16, 2007 at 10:20 PM
Suggested Repair
Rent a steering-column spring compressor or retainer tool from an auto parts store such as AutoZone. Use it to compress the center spring, plastic retainer, and metal plate so the snap ring can be installed.
Conversation Summary
The owner of a 1991 Buick Century replaced a steering-column spring so the left turn signal would cancel, but could not compress the center spring, plastic retainer, and metal plate enough to reinstall the snap ring. The expert said a special rental tool is required and makes reassembly straightforward.
