2003 Buick Century Windows fogging up
63,000 MILES • 6 CYL • FWD • AUTOMATIC
BDJAG
When it is rainy & humid (above 60 degrees outside) the inside of the car fogs up and the windows will not clear. I have tried the defroster and also turned on the air conditioner. Nothing seems to work. Took it to garage and they could not locate the problem. They did say there was proper air flow out of the vents.
May 8, 2008 at 1:02 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:10991a1d89="bdjag"]Air Conditioning problem
2003 Buick Century 6 cyl Front Wheel Drive Automatic 63000 miles
When it is rainy & humid (above 60 degrees outside) the inside of the car fogs up and the windows will not clear. I have tried the defroster and also turned on the air conditioner. Nothing seems to work. Took it to garage and they could not locate the problem. They did say there was proper air flow out of the vents.[/quote:10991a1d89]
Is the car garage kept? Is it Fogging up or is it Condensation? Have you tried using the heat?
If you've tried the above have you check your coolant level? If you have a coolant leak in your heater core it will cause this problem, but only when the heat or vent is on.
May 12, 2008 at 9:45 AM
