Engine will not crank over
JEEPFAN
  • 135 POSTS
Check all of your fuses and if they are all good then check your fuel pressure
Monday, July 6th, 2020 AT 5:07 PM (Merged)
  • 109,885 POSTS
Glad you got it fixed. Let us know if you have questions in the future.
WESLEYJR
  • 1992 BUICK CENTURY
  • 3.3L
  • 6 CYL
  • 200,000 MILES
Put a new fuel pump ina week ago it went out put another one in and it want start.
CARADIODOC
  • 33,916 POSTS
Your title says it wont crank but your description implies it cranks but wont run. Which one is it? Do you hear the fuel pump hum for one second after turning on the ignition switch? Have you checked for spark? What about diagnostic fault codes?
"Went out" doesn't tell us anything. We need details to form a plan of action.
NOCLUEDUDE
  • 5 POSTS
  • BUICK CENTURY
Hi, I have a '90 Buick Century that has been giving trouble lately. It dies after driving for a bout 20 minutes, and then it won't even crank or click or anything. After about 20 minutes starts right up normally. The weird thing is, it only does it if the Ac has been on, when I leave it off, it won't do this. Does anyone have any idea of what maybe causing this. Any help Would be greatly appreciated. Thank you.
MERLIN2021
  • 17,250 POSTS
2 items are suspect here, 1. Check the CKP, and then have a look in between your radiator and a/c condenser, see if there is a lot of road grime in there, if so get an air gun with long extension and blow out in both directions, til its clean!
MELODY1313
  • 1990 BUICK CENTURY
Electrical problem
1990 Buick Century 6 cyl Front Wheel Drive Automatic
Stopped at gas station and then would not start. Engine turns over but no spark. Battery is okay.
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
