1989 Buick Century No Crank
MICHEL
Hi, my buick century limited 89 3.3l have a problem, the stater dont crank but my battery is full of charge,
is it the starter, the solenoid, or the relay ...or maybe the ignition switch, i dont want to change all off them, some help please
Thanks
Aug 13, 2007 at 11:57 AM
  • 75,988 POSTS
[quote:7bdd56f2bd="Michel"]Hi, my buick century limited 89 3.3l have a problem, the stater dont crank but my battery is full of charge,
Thanks[/quote:7bdd56f2bd]
Okay I understand the budget
Find the starter-get a remote starter or improvise one hook it up to the Battery cable terminal on the starter, the other to the S terminal -I forgot the color-I think its purple!!!!! press the button -did the starter operate- do this and comeback and tell me what's the scoop.
Aug 13, 2007 at 8:07 PM
MICHEL
[quote:e036efb8d2="rasmataz"][quote:e036efb8d2="Michel"]Hi, my buick century limited 89 3.3l have a problem, the stater dont crank but my battery is full of charge,
Thanks[/quote:e036efb8d2]
Find the starter-get a remote starter or improvise one hook it up to the Battery cable terminal on the starter, the other to the S terminal -I forgot the color-I think its purple!!!!! press the button -did the starter operate- do this and comeback and tell me what's the scoop.[/quote:e036efb8d2]
Ok there is the scoop, i did it, yes its purple,i removed it and i connected the battery direct on it (negative on the base and the positive on the S terminal) and the starter ran very slowly, very hard to run, some times i had to knock it to run, and the gear is not come out to the fly wheel ,i think its shorted or whatever but when the starter was in place, i turned the ignition switch and the headlamps still very bright(if it can help someone) so i think i'll buy a new one. Many thanks for the reply, i'm very appreciate it, excuse my english and how can i make a donation from Canada???
Thanks
Michel
Aug 16, 2007 at 3:22 PM
  • 75,988 POSTS
[quote:dc5bd26d7d="Michel"][quote:dc5bd26d7d="rasmataz"][quote:dc5bd26d7d="Michel"]Hi, my buick century limited 89 3.3l have a problem, the stater dont crank but my battery is full of charge,
Thanks[/quote:dc5bd26d7d]
Find the starter-get a remote starter or improvise one hook it up to the Battery cable terminal on the starter, the other to the S terminal -I forgot the color-I think its purple!!!!! press the button -did the starter operate- do this and comeback and tell me what's the scoop.[/quote:dc5bd26d7d]
Thanks
Michel[/quote:dc5bd26d7d]
Go back to the main page scroll till you find the ( Make a small donation ) click on it and follow the instructions.
Thank You
Aug 16, 2007 at 6:14 PM
Suggested Repair
Replace the starter. A direct battery test on the removed starter showed slow, hard operation, occasional need to tap it, and no drive-gear engagement.
Conversation Summary
The owner of a 1989 Buick Century 3.3L reported a no-crank condition despite a fully charged battery and wanted to avoid replacing the starter, solenoid, relay, and ignition switch unnecessarily. The expert advised applying power directly between the starter battery terminal and the purple S terminal. The owner reported that the starter turned very slowly, sometimes needed tapping, and the gear did not engage the flywheel. With the starter installed, the headlights stayed bright when the key was turned. The owner planned to buy a new starter.
