AnnMarie:
It sounds like the either the starter is going bad, the starter relay, or the ignition switch. What you need to do is have a helper turn the key to the start position (when this happens) and see if there is power to the smaller wire on the starter. It should have 12+ volts. If it does, the starter is the problem.
Let me know what you find.
SPONSORED LINKS
Monday, April 12th, 2010 AT 9:48 AM
