Hi, if you think it is a fuel issue, use a gage and check fuel pressure. Can you check for possible trouble codes? At the least, you need an obd2 code reader. When looking at no code diagnostics, the list of possibilities, is as long as your arm.
SPONSORED LINKS
Tuesday, March 2nd, 2010 AT 12:46 PM
