1991 Buick Century wont start
MATTYBETTS
  • 1991 BUICK CENTURY
  • 6 CYL
  • FWD
  • 27,500 MILES
I replaced the fuel pump(gets good pressure now} and also replaced the fuel regulator. But the car will not start. The injectors are getting electric as I tested them with a test light. I sprayed a tiny bit of gas into the throttle body and it started but imedietly stalled. This tells me it is getting spark. I dont know what else to do. Please help
Saturday, August 21st, 2010 AT 7:07 AM
KHLOW2008
  • 41,814 POSTS
Hi mattybetts,
Thank you for the donation.
Did you test the injectors circuit for pulsing while cranking?
Was any other repairs carried out prior to this occurring?
Saturday, August 21st, 2010 AT 8:00 AM
MATTYBETTS
I used a test light to test the injector plugs, in which there was current to every one of them. I did not check the pulse. Is there a easy way to do this?
And no other repairs were done prior.
Saturday, August 21st, 2010 AT 8:11 AM
KHLOW2008
  • 41,814 POSTS
The injector curcuits are grounded by the PCM and to test if they are pulsing, you would need a noid light.
Disconnect the injector coupler and connect the noid light across the 2 terminals.
Crank engine and note if the noid light pulses. No pulsing means the PCM is not grounding the circuit and it could be bad.
Saturday, August 21st, 2010 AT 8:21 AM
MATTYBETTS
How would I repair the short in the pcm
Saturday, August 21st, 2010 AT 1:44 PM
KHLOW2008
  • 41,814 POSTS
If the PCM is bad, you would have to replace it or send it to someone who do rebuilds on them.
Before confirming if it is a PCM problem, check the continuity between the injectors and the PCM.
Saturday, August 21st, 2010 AT 11:31 PM
