1991 Buick Century car wont start
SKLOTZNER
  • 1991 BUICK CENTURY
  • 6 CYL
  • FWD
  • 170,000 MILES
I have been working on a 1991buick century limited with a 3300 engine. I was driving up a hill and allof a sudden the car slows down and when I reached the top it died. After I got pulled off the rode I started it again and it died So far we have replaced the ecm and the ignition control module. I did a diagnostics test on it and the codes I was given one of them were the tps throttle position sensor and another was the O2 sensor can anyone help please.
Thursday, August 13th, 2009 AT 7:25 PM
DESERTDOG
  • 8 POSTS
Sklotzner, Your lucky to have been able to pull a code. I would start with the TPS and check the wiring for shorts or opens in the circuit.
Normally an engine will run with a bad O2 sensor, but the TPS is a main component in the fuel delivery system and may require replacement indeed, Dog
Monday, August 17th, 2009 AT 1:10 PM
