1988 Buick Century Stalls in Gear
HANSEN36
I have a 1988 Buick Century. It will run fine but when you put it in gear it stalls. Any hints as to what it could be.
Dec 24, 2006 at 3:11 AM
ABADAY
  • 38 POSTS
check your tcc solinoid try un-pluging it to see if the stalling goes away
Jan 1, 2007 at 8:59 AM
BRAVESTAR1
  • 234 POSTS
I don't know if you still have the car, but when I had this problem it was the fuel pump.
I had to have it replaced, and when they installed it, they placed the suction sponge going sideways instead of front to rear, so everytime I go around a curve and have a 1/4 tank, the car stalls out on me.
Jan 23, 2009 at 2:36 PM
Suggested Repair
Unplug the TCC solenoid to see if the stall in gear stops. An expert with a similar stall found a bad fuel pump; if the pump was recently replaced, confirm the pickup sock is oriented front to rear rather than sideways.
Conversation Summary
The owner of a 1988 Buick Century said it runs fine but stalls when placed in gear. One reply suggested unplugging the TCC solenoid to see if the stall stops. An expert said a similar problem was the fuel pump, and after replacement an incorrectly installed suction sponge caused stalling on curves with a quarter tank.
