1988 Buick Century Stalling
KINGG33
I have an Buick Century, 1988, 102,000, V6 (not sure exactly which L type though). It stalls intermittently at a stop, in idle, or even sometimes when driving, and the check engine light is perpetually on. Just had it serviced, they cleaned the MAF, and replaced the computer module, and it ran nicely for about a half hour. When started up later, it returned to the exact behavior; when first started up, it stalls, and takes several tries sometimes, then runs rough in idle, and dies again. If this helps at all, one of the fuses (the one that runs the dome light, radio, horn, and power lock) has a short, and since these are non-essentials, I haven't had a fuse in place for several months. So I wonder if there are additional shorts causing problems to the computer module...? How difficult are shorts to fix?
Jul 15, 2007 at 5:25 PM
MERLIN2021
  • 17,250 POSTS
Unbolt the fusebox from the firewall and have a look...take negative cable off first!
Jul 20, 2007 at 12:40 PM
FMTHEFIXER
  • 11 POSTS
Sounds as if you may have a fuel pressure problem or you IAC (Idle Air Control) motor is dirty or sticking. Change your fuel filter first. If the fuel pump is 'loud', it's probably on it's way out. As for the IAC, unplug it, unscrew it from the air induction unit and clean it and the air passage way it screws into ....
Jul 30, 2007 at 10:57 AM
Suggested Repair
Disconnect the negative battery cable, unbolt the fusebox from the firewall, and inspect it for shorts. Also change the fuel filter and check fuel pressure and pump noise, then unplug and remove the idle air control valve and clean it and its air passage.
Conversation Summary
A 1988 Buick Century with about 102,000 miles stalls intermittently at idle, stops, and while driving, with the check engine light staying on. Cleaning the MAF and replacing the computer module helped only briefly. The owner also reports a short in a fuse circuit for the dome light, radio, horn, and power locks. Experts recommend inspecting the fusebox after disconnecting the battery, checking fuel pressure and the fuel filter or pump, and cleaning the idle air control valve and its passage.
