1996 Buick Century Stalling While Driving
KAZARNIE
I have a problem with my car stalling out as I drive. It cuts out as if I turned it off while I am driving. If I try to restart it right away it will try to start but chugs and dies out. But if I sit for a count to 25 it will start right up and I am on my way again. This will happen numerous times or it can happen once and run good. One day it will run as if it has no problem in the world but in the same breath you never know. Just curious if it could be my fuel pump, when I turn on the ignition I can hear the pump so not sure. It is a V6 3.1 Really would appreciate some input
Feb 2, 2006 at 4:30 PM
SC1 RACING
  • 117 POSTS
it does sound like a fuel pump. i owned a blazer that did the same thing. never got a engine light and ran fuel pressure test everything checked out fine, and it keep stalling, so i figured with that many miles id try the fuel pump. never died again. sold it to my neighbor 2 years ago and still going strong.
Feb 3, 2006 at 5:45 AM
KAZARNIE
I am going to change the fuel pump! It will be a learning experience since I have not changed one before. I really appreciate your input. Will let you know how things turn out, also if I run into a problem I might be asking another question or two. Have a Good Day
Feb 3, 2006 at 7:03 AM
Suggested Repair
Replace the fuel pump. Similar intermittent stalling that returned after a short wait was resolved by a fuel pump replacement even when no check-engine light appeared and a fuel-pressure test looked normal.
Conversation Summary
The owner of a 1996 Buick Century with a 3.1L V6 reported intermittent stalling while driving, as if the ignition had been switched off. Immediate restart attempts caused the engine to chug and die, but waiting about 25 seconds allowed it to start normally. The owner could hear the fuel pump when the ignition was turned on and asked whether the pump could be failing. An expert said the symptoms matched a fuel pump problem experienced on another vehicle, where testing showed no fault but replacing the pump stopped the stalling. The owner decided to replace the fuel pump.
