1985 Buick Century Starting Trouble?
KASSIK
  • 1985 BUICK CENTURY
  • 4 CYL
  • 55,000 MILES
Sometimes when the car is cold, it has trouble starting. It floods out and miss-fires. Then if you hold the pedal to the floor and keep cranking and cranking it will fire then run normally. It has had tune-up(plugs, cap, rotor), o2 sensor, fuel pump, fuel filter, head gasket, rebuilt tbi unit. What else could be wrong? Weak coil? Ignition module? Any ideas appreciated. Thanks!
Tuesday, February 9th, 2010 AT 1:18 AM
  • 109,951 POSTS
Has the check engne light been on? If so, what codes were retrieved?
Saturday, February 13th, 2010 AT 9:06 AM
KASSIK
The engine light has not come on so, no codes.
Saturday, February 13th, 2010 AT 9:25 PM
