1999 Buick Century 1999 century hard to start
1999 BUICK CENTURY
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
69LINDSEY
I have a 1999 Buick Century that is hard to start. It turns over for 5-10 seconds before starting and takes about 20-30 seconds to idle smooth. I can shut it off and it will start right back no problem. If it sets for 10 minutes or longer same problem. I have changed plugs,wires,fuel pump and fuel pressure regulator with no change in starting. No visible fuel leaks, have checked connections and fuel rails. What do I try next?
May 30, 2008 at 9:05 PM
BLACKOP555
  • 10,386 POSTS
check for a leaky fuel pump test port, also check for leaky fuel injectors, they could be bleeding off alot of pressure.
May 30, 2008 at 9:46 PM
69LINDSEY
The fuel pump o ring did not seal or was not in straight(don't know). I had the smell of gas coming from that area. I took it out reinstalled it with some sealant. Car starts fine now.
Jun 2, 2008 at 7:13 PM
BLACKOP555
  • 10,386 POSTS
glad to hear you have figured it out and it didnt cost you an arm and a leg.
Jun 3, 2008 at 8:03 AM
