I have good brakes it stops good but the brake pedal is about two inches of the floor when I press it down
184,000 MILES • 4.8L • V8
JOE1953
  • 812 POSTS
i replace the two brakes caliper on the rear and i bled the two calipers. i have good brakes it stop good, but the brake pedal is about two inches of the floor when I press it down. what height the brake pedal should be when press it down?
Sep 16, 2016 at 4:44 PM
HMAC300
  • 48,601 POSTS
if the pads were not replaced that is not too bad. check fluid level in master new pads in front especially will make it go higher.
Sep 17, 2016 at 3:17 AM
JOE1953
  • 812 POSTS
the front pads was replace July 23, 2016 and the rear pads was replace about a week later. the the brake fluid is at the maximum level.
Sep 17, 2016 at 3:45 AM
HMAC300
  • 48,601 POSTS
then you may still have air in ABS unit try a power bleeder If they do not come up then a mechanic will have to use a scanner to bleed so he can open the valves on ABS. it can take up to three quarts to get air out.
Sep 17, 2016 at 5:54 AM
JOE1953
  • 812 POSTS
how do I use a power bleeder? what do I connect it to? is the power bleeder a hand pump? are you saying it takes three quarts of brake fluid?
Sep 17, 2016 at 1:05 PM
HMAC300
  • 48,601 POSTS
the power bleeder is either powered by air or some have a pump you fill it with fluid put air in it either by hand or air tank, install on master cylinder then bleed brakes.
Sep 18, 2016 at 8:17 AM
JOE1953
  • 812 POSTS
can you send me a video showing how to use the power bleeder?
Sep 18, 2016 at 9:27 AM
HMAC300
  • 48,601 POSTS
we dont' have that this is the only one we have. a power bleeder setup isn't
very hard to hook up a rent it shop can explain it.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Sep 18, 2016 at 10:22 PM
